This is an example of how to make an interaction with 3D Picture control. It may be treated as an example of use of Pick Model, WindowToObjectCoords and SetBillboardParams methods related to 3D Picture control (which are not covered by any of examples shipped with LabVIEW) as well as example of many others methods and properties related to this control includig creating and manipulating of simple 3D objects and meshes. As edited surface is represented by 3D spline, the code may be also treated as an example for spline interpolation routines.
The application is an interactive editor of 3D surface defined as 2D array of nodes. The space between nodes is filled with 3D mesh calculated by spline iterpolation between the nodes. User edits nodes' coordinates interactively by clicking and dragging directly on 3D Picture control. Surface edition starts with simple 3x3 flat set of nodes which may be dragged in any direction and the number of nodes may be changed in order to get a complex 3D surface.
<object id="scPlayer" width="888" height="684" type="application/x-shockwave-flash" data="http://content.screencast.com/users/vugie/folders/Jing/media/bfecc6f6-0256-4d10-8477-23f0a6e4518a/ji..." > <param name="movie" value="http://content.screencast.com/users/vugie/folders/Jing/media/bfecc6f6-0256-4d10-8477-23f0a6e4518a/ji..." /> <param name="quality" value="high" /> <param name="bgcolor" value="#FFFFFF" /> <param name="flashVars" value="thumb=http://content.screencast.com/users/vugie/folders/Jing/media/bfecc6f6-0256-4d10-8477-23f0a6e4518a/Fi..." /> <param name="allowFullScreen" value="true" /> <param name="scale" value="showall" /> <param name="allowScriptAccess" value="always" /> <param name="base" value="http://content.screencast.com/users/vugie/folders/Jing/media/bfecc6f6-0256-4d10-8477-23f0a6e4518a/" /> Unable to display content. Adobe Flash is required. </object>
Excellent example, very helpful! Thank you!.
Awesome example of the power of the 3D picture control.
I've looked at this example multiple times in the past.
The documentation and examples for LV's 3D picture is woefully lacking. (As of 2012 at least).
Do you think you could take the time to write a nugget on the NI forums outlining how to get working with the 3D picture? I've considered it myself a few times but you seem to understand it's workings a lot better than I.
I do not have too much time for this, but I recommend you searching lavag.org forums with "3d Picture" term (with quotes). Many issues were discussed there.
Lots of clever tricks, clean programming, well documented.Thank You!
