Example Code
3D Plot with Pseudo 4th Dimension as Intensity
Code and Documents
This VI uses the 3D surface graph to plot sets of X, Y and Z data with a 4th dimension represented by intensity. The VI generates X, Y, and Z data arrays representing sampled (X,Y,Z) data points of several quadric surfaces. It graphs them using the Plot3dMesh method of the 3D graph. The VI then uses the inverse of the Z array as the intensity array (the W Vector of the 3D mesh). The VI also demonstrates some of the lesser known functionality of the graph, such as color, that you can use programmatically with Invoke and Property Nodes.
You can change the X, Y, and Z input arrays to the plot to represent any 3D surface that can be represented by a function f(x,y,z). The fourth input, W, is the intensity array.
Comments
ErikL68
Member
Member
on
It seems this does not work in my LabVIEW version - 64-bit 2025Q3.
The graph control itself could not be loaded, and the sub-VIs Basic Properties.vi and Convert OLE Color.vi were not found.
Is this a 32-bit vs. 64-bit issue, or just a version difference issue?
Contributors
