Description
Description-Separate-1A Bitmap Resize Algorithm
This article handles a simple algorithm to resize (enlarge or reduce) computer pictures.
http://www.davdata.nl/math/bmresize-old.html
Description-Separate-2How to Use
How-Separate-1We regard the bitmaps as pieces of paper.
A pixel is given the dimension 1 * 1.
The destination bitmap dimensions are the dimensions of the source bitmap
divided by a factor f.
So, for each destination pixel, a corresponding area (f*f) on the source map may be drawn.
In most cases, this area will partially overlap the pixels in the source.
The color of a destination pixel is the (weighted) addition of the colors of
the pixels covered on the source map.
In the picture above, 4 pixels in the source contribute to the (marked) pixel
in the destination.
This contribution is proportional to the area covered.
How-Separate-2
