Example Code
AM Modulation using Labview FPGA and NI 5640R
Code and Documents
This is the fine example that illustrates the Both the Modulation and Demodulation of Amplitude with a Modulating signal of 100KHz, both at the receiving end and transmitting end and a carrier at 21.4 MHz.This example has been tested and verified with Oscilloscope Also.
Hello FriendsFirst Go through the example and understand the terminology and its representation. Like how the loop works and what are our requirements, are we meeting it. Also understand what is HOST and What is FPGA Target. Come up with the Errors, Errors are the only source that makes u perfect in LV.From rajeshg@icsgloabl.biz
Contributors
