Overview
This VI can prevent users from aborting a VI, using the Abort Execution button, instead of using a stop button
Description
There are a few less-known but helpful VI properties. One of which is the ShowAbortButton property. This way you can prevent VI users from aborting a VI instead of using a stop button. Using the TB.ShowAbortButton Property Node, which indicates whether to display the Abort Execution button on the toolbar, while the VI runs, the VI can prevent users from aborting a VI using the Abort Execution button on the front panel.
Requirements
LabVIEW 2012 (or compatible)
1. Run the VI
Additional Information or References
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
