Example Code
Acquire Waveforms and Resample them using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
1. Overview
This example shows how to acquire waveforms in one loop, while reading those same waveforms and resampling them for display in a different loop.
2. Description
Using a producer-consumer architecture. The example shows a producer loop that generates (or acquires) waveforms and sends them to the consumer loop by using a Queue. In the consumer loop, the program resamples the waveforms according to the selected decimate rate to later show them in a chart.
3. Requirements
  • NI LabVIEW Professional Development System 2012 or compatible.
4. Steps to Implement or Execute Code
  1. Download and Run the VI.
  2. Select a decimation rate.
  3. Observe how the waveform appearance changes as you change its sampling rate.
  4. Press the stop button when done.
5. Additional Information or References
Acquire waveforms and resample Screenshot.PNGAcquire waveforms and resample Screenshot.PNG
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Stephen B
