Overview
This example VI demonstrates how to acquire sounds from the PC's sound board, filter it and output the filtered signal back to the PC's sound board.
Description
In LabVIEW you are able to acquire signal from your own PC's sound board, then you can filter it using the numerous functions already present in the development environment and finally output the signal using easy-to-use LabVIEW APIs. In this example a Producer - Consumer design pattern is used to transfer stream data from the acquisition loop to the ouput loop, while native LabVIEW APIs are used to interact with the sound board of the PC.
Requirements
Additional Information or References
VI Block Diagram
