Example Code
Acquiring the Coefficients for an Initial Value Linear System of Differential Equations using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates how to programmatically solves differential equations and displays the corresponding coefficients and eigenvalues.
Description
Here is a brief description of the example:
LabVIEW can calculate the value of a system of differential equations at a given time, but does not return the constant coefficients used to perform the calculation. This VI returns the coefficients and corresponding eigenvalues used for these calculations. Because it is possible for some of the coefficients to be zero, duplicate eigenvalues are returned.
Two numeric arrays are returned. The values at corresponding indices of the arrays are coupled in the formula used for calculation. For instance, if the first value in the coefficients array is 1.6 and the first value in the eigenvalues array is -1, that portion of the solution is 1.6*exp(-1*t).  When an eigenvalue is repeated, the following values should be another equation in the system.
Note that, because this VI parses the formula from a string and converts the values to numeric, this VI will only work for real numbers.  It could be modified to work with complex numbers, but would require some more checking of the formula string.
Requirements
  1. LabVIEW 2012 (or compatible)
  1. Open the attached "Get Coefficients and Eigenvalues.vi"
  2. On the front panel, configure the desired inputs "A (matrix of coefficients)" and "X0 (start value)
  3. Run the VI
Additional Information or References
VI Snippet
Donovan
