Example Code
Acuity AR200 Laser Profilometer Position String Parsing
Products and Environment
    Hardware
  • Instrument Control
    Software
  • LabVIEW
Code and Documents
Overview
This VI parses the string returned by an Acuity Research AR200 Laser Profilometer. It returns the hexadecimal string position data as a 1-D array of 16-bit integers (U16 data type).
Description
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached VI
  2. Run the VI
Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
David G
Sales Engineer - SE Michigan & N Ohio
Comments
Todd S.
NI Employee (retired)
on
Thanks for posting.  Do you mind linking to other documentation/information about the AR200?  That way anyone who stumbles across this can learn more.
Todd S.
LabVIEW Community Manager
