Example Code
Add ENUM Definitions to LabVIEW DLL Header
Code and Documents
Introduction
The following example provides a technique for applying ENUM control definitions to a LabVIEW DLL header file. This addition allows developers to pass list items used in LabVIEW ENUM controls, as parameters to DLL functions by name. The example requires that all functions (VIs) used in the DLL creation be placed in a single directory. The code was designed using VI Server to extract the ENUM control attributes, and apply them to the .h file.
Note
For additional information on the functions used in this example. Please use CTRL+H to view the LabVIEW Context Help
Patrick Corcoran
Application Engineering Specialist | Control
Contributors
