Example Code
Adding Color Levels to a Tank Indicator
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example program demonstrates how to manipulate the sliders of a tank indicator to display different colors at various numeric ranges.
Description
The idea with this code is to change the color of a slider indicator in order to have different colors at various ranges. This might be useful to alert the user with colors that the slider has passed a specific limit.
Requirements
LabVIEW 2012 (or compatible)
1.Set the High and Low Limit controls to adjust the color transition levels.
2. Set the colors for each level.
3. Adjust the Value of Tank control and observe.
4. Finish execution with the Stop button.
Additional Information or References
Front Panel:
Block Diagram:
