Example Code
Adding Custom Menu Using VB Script in DIAdem
Products and Environment
    Software
  • Diadem
Code and Documents
Description
This example shows you how to add Custom menu with icon.ico in VBScript.
How to Use
  • How to add custom menu :
    1. Open the Script tab of the DIAdem.
    2. Run the script, Add_Custom_Menu.VBS in attached file.
    3. A custom menu is created with the Car_icon.ico file icon and stored in the DIAdem setup file Desktop.DDD. This menu will persist when running DIAdem.
    4. The VBS file connected to the custom menu is Load_DIAdem_dialog.VBS. This VBS is the Dialog box that loads the Data portal data.
  • How to delete custom menu :
    2. Run the script, Remove_Custom_Menu.VBS in attached file.
    3. The custom menu is deleted. And, the changed configuration is saved as desktop.DDD.
The custom menu created is as follows:
