Example Code
Adding array compatibility to NI_Database_API.lvlib using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates the way to add array compatibility to NI Database API.lvlib
Description
Here is a brief description of the example:
The author has changed 2 vi's to allow an array to be written to a database, in addition to the cluster. I've duplicated case for "Cluster" to handle "Array" in DB Tools Parser.vi, and I've added outside brackets to DB Tools Build Insert Query.vi to allow empty data cells to be treated as valid.
Requirements
  1. LabVIEW 2015 (or compatible)
  1. Open NI Database API.lvlib; DB Tools Parser.vi and DB Tools Build Insert Query.vi
  2. According the related function, select different VI
Additional Information or References
VI Snippet
DB Tools Parser:
DB Tools Build Insert Query:
