Example Code
Advanced Search String SubVI with Selectable Case Sensitivity
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to add a selectable case sensitive functionality to the Search/Split String VI.
Description
This code searches the input string for the strings in the array "Strings to Find" and returns information on if (Any Found?), what (Output Strings), and where (Indeces Found) the strings were located. The search can even be customized to include or ignore case sensitivity.
The "Output Strings" array results in the same number of elements as "Strings to Find." It contains the found string at a given index if indeed the string was found, or the empty string if the string was not found.
The "Indices Found" array contains the index in "String to Search In" at which the corresponding element of "Strings to Find" was found, or -1 if the string was not found.
For example, if the string at index 2 in "Strings to Find" was found in the input string, then the element at index 2 of "Output Strings" will contain that same string. If that string was not found, then the element at index 2 of "Output Strings" will be the empty string.
Requirements
LabVIEW 2012 or compatible
1. Select if you would like to make a Case sensitive search
2. Insert the string to search in
3. Insert the strings to find
4. Check the Any Found? LED and both array indicators
Additional Information or References
