Example Code
Amplitude-Modulated (AM) Signal Generation (NI-FGEN, Simulated)
Products and Environment
    Software
  • LabVIEW Modulation Toolkit
Code and Documents
Description
Overview
This example demonstrates how to generate a amplitude-modulated signal using a NI-FGEN waveform generator. This program is a shipping example VI included with the Modulation Toolkit for NI LabVIEW.
This Virtual Instrument is designed to work with RF communications hardware from National Instruments.
This software is written in LabVIEW, a graphical programming language designed for scientists and engineers..
Modulation Toolkit Example Programs
The National Instruments NI Modulation Toolkit For LabVIEW extends the built-in analysis capability ofLabVIEW with functions and tools for signal generation, analysis, visualization, and processing of standard and custom modulation formats. With this toolkit, you can rapidly develop custom applications for research, design, characterization, validation, and test of communications systems and components that modulate or demodulate signals. Applications for the Modulation Toolkit are numerous; it includes the modulation formats - AM, FM, PM, ASK, FSK, MSK, GMSK, PSK, QPSK, PAM, QAM - that are the foundation of numerous emerging wireless technologies such as 802.11 a/b/g, ZigBee (802.15.4), WiMax (802.16a), RFID, satellite communications, and commercial broadcast among others.
More information on National Instruments signal processing can be found at the Signal Processing Resource Center.
Front Panel
This is a picture of the VI's front panel. To view the block diagram and additional documentation, download the attached file.
Related Links
