Overview
How to connect any sensor to LabView
Description
By attached library you can very easy to connect any of I2C or SPI sensor to LabView. You need only USB to I2C/SPI interface UMFT4222EV.
Than you can use entire powerful graphical interface of LabView to present sensor's data.
What you can do:
1. To connect any I2C/SPI device to LabView
2. To evaluate newest MEMS sensors.
3. Fast debugging algorithms to manage sensor's data.
4. To build simple DAQ cards by using I2C/SPI DIO and ADC .
Hardware and Software Requirements
LabView and UMFT4222EV board
1. Download the zip file.
2. Install driver D2xxx.dll for UMFT4222EV. Read the Documents\DS_UMFT4222EV.pdf
3. Read datasheet on you sensor in order to understand I2C /SPI communication protocol.
4. Open and edit according your I2C /SPI communication protocol one of examples FT4222_I2C.vi or FT4222_SPI.vi
Additional Information or References
