The application assists you in configuring the Vision system by helping you select the appropriate camera for the application from the information about the dimesnions of the Object under inspection and the dimensions of the smallest detail on the object to be percieved completely for the inspection. Further it adds a functionality to Configure the working distance and Lens combination too.
Thanks and Regards,
N A Gokul
Application Engineer,
NI India
this is a good app. great job N A Gokul.
BTW a quick feedback, beside only showing the suitable camera based on the given FOV and the given smallest features to be measured, I think it should also display a higher spec. of camera can also be chosen.
Thanks Krisna,
Soon I'm going to post a newer version of the application.. this will have the options you mentioned and a few more too.. Followed by this, I'm also making a lighting advisor and lens advisor..
