Example Code
Apply Offset to Signals
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code demonstrates how to add an offset to a simulated signal then return those updated signals to a signal waveform graph.
Description
This code will show a simple way on how to add an offset to a signal, and how to change the plot name of the graph. These are two features that are normally requested for different purposes. We can easily allow the user to select the name of the plot, by changing the constant string in the block diagram to a control.
Requirements
LabVIEW 2012 (or compatible)
1. Select the Run button.
2. Review the block diagram.
Additional Information or References
A_Ryan
AES
