Example Code
Archery Score Card
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
For those who are interested in archery or who wish to know how the sport is scored.
Description
A scoresheet where you can select the points you've scored and it highlights the ring on the target. The file is saved to .CSV at the end.  A LabVIEW 2013 project have been attached.
Requirement
  1.  LabVIEW2013 (or compatible)
  1. Input the points using the buttons.
  2. The results will be saved to a spreadsheet after the program finishes
Additional Information or References
Block Diagram
