Example Code
Array of Doubles to an Array of Strings
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example will convert an array of doubles to an array of strings.
Description
This VI will convert an array of doubles to an array of strings. You can easily modify this code to allow other conversions.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Initalize an array of doubles.
  2. Use the Number to Fractional String VI to convert the array to a string.
  3. Add the appropriate indicators.
  4. Run the VI directly and the indicators will show the converted result.
Additional Information or References
Front Panel
VI Snippet
Example written by Vimal Fernandez
