Overview
This code is a 3 layer MLP complete with a back propagation option for network training on datasets (I have a variable number of hidden layers code set up if there is demand for it).
Description
The MLP in this code can be executed with any number of input and output nodes but with one set of input nodes, one set of hidden nodes, and one set of output nodes. It will require two 2-dimensional arrays for the two sets of weights. Run the Demo.vi to get an idea how the code works. The demo example uses to inputs (x,y) with any number of hidden neurons (10 by default) and two output (red, green).
Requirements
Software
LabVIEW 2009 or higher
Hardware
Anything that can run LabVIEW 2009 or higher
Additional Images or Video
REVISE ESTE EJEMPLO, PERO SERIA UTIL QUE TAMBIEN SE PUEDA EXPLICAR COMO EMPLEAR EL TOOLKIT MACHINE LEARNING Y LA UTILIZACION DE LOS ICONOS DEL MISMO ACERCA DE REDES NEURONALES
To provide more detail on the example Demo.vi: The code that drives the neural network is ANN.vi. Demo.vi runs using the ANN.vi routine to demonstrate how to use it. ANN.vi is a general purpose 3 layer ANN that can be used for any number of inputs and outputs. In this example, the user sets the data points for training (x,y position for two colored catagories) and the ANN trains on that data. During training, the user can have the NN ingest additional data to observe where the classification boundaries are on the graph both during and after training.
