Overview:
Programmatically adjust the widht of the control depending on the data value.
Description:
This code calculates how many digits the control value has and adjust the widht of the control by detecting when a change is made using the Event Structure Functionality.
Requirements:
LabVIEW 2012 (or compatible).
Steps to Implement or Execute Code:
1. Run the VI
2.Modify the value of the control by increasing or decreasing.
Additional Information or References:
"**This document has been updated to meet the current required format for the NI Code Exchange.**".
Thanks for posting! Could you please rename your file to include the LabVIEW version (ie. "_lv86.vi")?
whoops, put the version in the wrong title... first time ![]()
