Description
Description-Separate-1If you are trying to fulfil the FDA CFR Part11 requirement that [TestStand] shall log out the user if the user is inactive for 15 minutes. How can you implement this in TestStand?
Description-Separate-2How to Use
How-Separate-1
Set-Up:
- Open NI TestStand 2019
- Download the SequentialModel with Watchdog sequence found in the Attachment section
- Create a new sequence that opens a message pop-up
- Go to Edit and select Sequence File Properties
- Go the Advanced and in Model Option: choose Require Specific Model
- Select the Sequence File with Watchdog file.
- This has now set the process model for the new sequence to be the Sequence File with Watchdog.
- To test the sequence, go to Execute and select Single Pass.
Expected Results:
- Once clicking "OK" on the message pop-up, a message will appear saying "Watchdog Started"
- This will then disappear.
- If you Restart the sequence another message pop-up will appear saying "Watchdog Reset"
- If you wait 15seconds before starting a new execution a message pop-up will appear saying "Logged out Terminated Execution"
- The user will be logged out (greyed out functions) and the sequence terminated.
How-Separate-2Additional Information
Additional-Separate-1The example is written for a single-pass entry point. I have mapped the code across to the Test UUTs entry point, which does work, however, this can be improved by:
- In the current code mechanism, offering a choice to the user to log out of the system depending on inactivity between UUTs or between executions.
- Considering the UUT Serial Number input box is already waiting, implementing a timeout feature here would be a better/cleaner approach.
Additional Information of attached method:
- The SequenceFileLoad callback is used to create the station globals that are required for this Process Model to operate.
- The watchdog is started in a new execution which enables it to run in the background when the main sequence is finished.
- The time for the watchdog to look for inactivity is found as Locals.TimeLimit in the Watchdog Sequence.
- Note that there is also a wait interval function that can be changed in the Watchdog sequence.
Additional-Separate-2
