Overview
This VI shows how to use basic front panel properties.
Description
This VI demonstrates how to use property nodes to show/hide the menu bar, show/hide the title bar, and to make the VI transparent. It also shows how to use an invoke node to center the front panel. The while loop allows the code to run continuously until the stop button is pressed or an error occurs.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
1. Run the VI
2. Use the “Show Menu Bar?” toggle switch to show and hide the menu bar
3. Use the “Show Title Bar?” toggle switch to show and hide the title bar
4.Use the “Make VI Transparent?” toggle switch to change the front panel's appearance
5. Use the “Center the VI” button to center the VI on your screen
6. Click the “STOP” button to end the program
Additional Information or References:
