Overview
Turn this:
into This:
With a keystroke.
Description
The VI will add a QuickDrop-shortcut to your LabVIEW and will enable you to select an area on the Blockdiagram, press Ctrl+Space - Ctrl+M to surround it with a benchmarking-structure.
It will also enable you to add benchmarking to selected loops like this:
Ctlr+Space - Ctrl+Shift+M
The VI is created using VI scripting, but scripting must not be enabled to use the VI as a Shortcut.
Once you copied the VI to the QD-plugins-folder ([LabVIEW]\resource\dialog\QuickDrop\plugins) you can run it via Ctrl+M (benchmark selected area), or via Ctrl+Shift+M (benchmark loop).
Both shortcuts of course work with more complex code than shown above.
The VI is full of comments and ready to be edited. It is also a good example for using scripting to create and wire Blockdiagram objects.
Requirements
LabVIEW 2014 or later
