Example Code
Binding Shared Variables using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows that you can create an enum to limit the variables that a user can use to select from.  To accomplish this, it gets the string text from the enum and inputs it into a String to Shared Variable vi
Description
Requirements
Software:
  1. LabVIEW 2012(or compatible)
  1. Unzip the attached folder to your computer
  2. Open the VI "SharedVariableEnumBinding_LV861 2012 NIVerified.LVProj"
  3. Run the program
Additional Information or References
VI Snippet
Bryan H.
