Overview
This example generates data and transforms it into a biphase Manchester encoded signal. This VI also utilizes FPGA block memory to store the generated data in the encoded form.
Description
Manchester coding is used in situations where you want eliminate data-dependent DC components, and/or where you want self-clocking behavior. Self-clocking means that a Manchester-encoded signal can actually be interpreted correctly without a clock signal.
Manchester Encoding Functionality:
-- Each bit is transmitted in a fixed time (the "period").
-- A '0' is expressed by a low-to-high transition, a '1' by a high-to-low transition.
-- The transitions which signify 0 or 1 occur at the midpoint of the clock period.
-- Transitions at the start of a period are overhead and do not signify data. These are necessary when a series of 0's or 1's repeat.
Since we have a transition at least once for every data bit, we ensure that we won't have a DC signal if the data stays constant. Also, assuming data gets sent about the formation of the signal (or if both parties know the signal frequency), a clock signal is not necessary.
This diagram is an example of Manchester encoding:
Note that the data transfer always occurs at the falling clock edge. When the data repeats we have to do one of those "overhead" transitions on the rising clock edge.
Requirements
Software
LabVIEW 8.5 (or compatible)
LabVIEW FPGA
Hardware
(optional) NI FPGA with DIO capabilities
1) Download and extract attached zip file
2) Open project file.
3) Set the FPGA target to execute on the development computer, or add your own FPGA target to the project and move the VIs over
5) Open "FPGA Generate Manchester Signal Stream from Block Memory.vi" - if needed, modify the "Clock Out" and "Data Out" DIO lines to correspond with your new FPGA target
6) If needed, adjust the repetition rate and other signaling parameters
7) Run the VI
Additional Information or References
There is some additional IP included in this project
--an IP block for Inline 16-bit cyclic redundancy CCIT checking
--An IP block that shows the logic behind Manchester encoding
--An IP block for an 8-bit Fibonacci Linear Feedback Shift Register
Thanks help me a lot with the new FOBik - TRW Automotive
