Overview
This VI will reliably discover available Bluetooth devices and return their addresses and names
Description
If you ever wanted to monitor the Bluetooth devices around you, this cool feature of LabVIEW will make it possible. This reliable Bluetooth discovery VI runs service discovery on every device with a blank name, this will always return a name. This is at the expense of discovery time, this can take a LONG time, hence the time to discover code for Benchmarking.
This VI uses the Bluetooth RFCOMM Service Discovery available in the Bluetooth Palette inside Data Communication.
Requirements
LabVIEW 2012 (or compatible)
1. Download the VI "Discovering Bluetooth Devices_LV2012_NI Verified"
2. Run the VI
Additional Information or References
