Overview
This VI demonstrate how to implement a count of how many distinct time a Boolean Indicator reads True
Description
Here is a brief description of the example:
By using a Case Structure controlled by the current boolean value and a Shift Register to store the Boolean value of the previous iteration, we can keep an accurate count of how many times the LED indicator changes from F to T. This solution does not use an Event Structure nor any Local Variables, and is not blocking.
Requirements
Additional Information or References
VI Snippet
You can do this a lot simpler by using the Boolean Crossing PtByPt.vi
