Example Code
Building a Calculator with a LabVIEW XControl
Products and Environment
    Software
  • LabVIEW
    Other
  • XControl
Code and Documents
Description
This example demonstrates how to use a LabVIEW XControl. The Calculator XControl can manipulate values similar to a handheld calculator. The value of the XControl is the current calculated value shown in Output.
Open the Calculator XControl Project included with this example to see the configuration of the XControl. The project includes the XControl VIs and controls, as well as the Calculator Example VI that implements the XControl.
Related Links:
Creating New Front Panel Objects with LabVIEW XControls
LabVIEW Online Help: Using XControls
