I've updated the UI example:
C:\Program Files (x86)\National Instruments\TestStand 2021\UserInterfaces\Simple\CSharp\Source Code
and can see a UIMessageCodes.UIMsg_Trace message type in the callback of: axApplicationMgr_UIMessageEvent() when running a .seq file.
this is when my sequence file is using the "sequential model".
when i try to run a "batch model" sequence in the same UI code, a " UIMessageCodes.UIMsg_Trace" message is NEVER received.
these messages are received:
UIMsg_ReportLocationChanged
UIMsg_ReportChanged
UIMsg_ModelState_PostProcessingComplete
UIMsg_EndFileExecution
so something is working.
I've got access to TS 4.2 code, and the Trace message does appear when I expect it, but I've not spotted any dfference between the code.
Further to this:
I just downloaded TS 2022 and the behaviour is as expected/desired.
Either TS 2021 is configured incorrectly, or it has a bug?
Figured it out.
If the "Hide Execution Windows" is CHECKED, the trace message does NOT appear in the AxApplicationMgr_UIMessageEvent callback.
