Example Code
CMD + WLAN
Products and Environment
    Software
  • LabVIEW
    Operating System
  • Windows
    Programming Language
  • LabVIEW G
Code and Documents
Description
Hello everybody,
after a long time I decided to make my CW Commander accessible to everyone.
It is an LV project that simplifies communication between a PC and a WLAN network.
The zip file contains all necessary VIs (some password-protected) and other settings to create EXE and installers.
The forwarding from the CW Commander to a further module is also accessible and only needs to be adapted to your project in the ini file.
Maybe you can learn something from it and implement it in your own projects.
If you have any questions, get in touch. However, I rarely look into the forum.
The easiest way is to send me an email to: mail@joachimkranzen.de
Good luck with WiFi in your own project!
greetings
Joachim
Additional Information
programmed using LabVIEW 2015 professional
