Example Code
Calculate Overall Image Intensity
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
The example demonstrates how to calculate the mean intensity of an IMAQ image section.
Description
With the 'IMAQ Histogram' function it is possible to calculate the overall intensity of an image or the intensity of an image section.
To calculate the intensity of an image section a mask has to be created. The mask normally is created from a ROI (region of interest) that in this example can be easily selected by the user with the 'IMAQ ContructROI' function.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Run the VI
  2. Select any available ROI (region of interest) tool and create a ROI and click OK
Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Ashish Naik
Automotive Business Development Manager
National Instruments UK
Comments
udka
Active Participant
Active Participant
on
I don't understand why so much complexity? Use IMAQ ROIProfile VI with given ROI, no need of masking, casting.
Edit: Also the heading is misleading, is it Overall Image Intensity or the selected Region Mean Intensity?
uday
