Example Code
Calculate the Magnitude of a Vector
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to calculate the magnitude of a vector by two separate means.
Description
This VI shows how to calculate a vector's magnitude using two different methods. One method uses the complex math routines in LabVIEW, and the other uses the Pythagorean Theorem, given the X and Y magnitudes.
Requirements
LabVIEW 2012 (or compatible)
1. Insert the values for X and Y
2. Select the Run button.
Additional Information or References
Product Support Engineer
