Overview
This example demonstrates the standard calculator.
Description
You can simulate simple math calculation by the standard calculator on the front panel.
Event structures can be used for a click-event application.
Requirements
Additional Information or References
VI Front Panel
Note to people: It's password protected.
Hi Wouter,
Need to know about your views on this.
You can check this
This will help you
https://decibel.ni.com/content/docs/DOC-22535
http://lavag.org/files/file/209-calculator-xcontrol-lv2010/
This is in latest version. Can you update it in version 8.6. Even i have asked you to convert Vi to version 8.6 in my query regarding
Now Check With
https://decibel.ni.com/content/docs/DOC-22536
Lower version is added
This might help you......
Hi Prabhakant,
Lower version is not opening ![]()
Can you please check
