Say you created an executable for your main VI, and the main VI opens and closes a subVI's front panel through an invoke node. However, when you build the executable, this subVI does not open or throws an error that it doesn´t find it. What should you do?
Description-Separate-2
The steps to call a subVI dynamically within an executable is:
Attached is an example for LabVIEW 2018.
How-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
