Example Code
Calling LabVIEW created dll from Visual Basic6
Code and Documents
A comprehensive example that illustrates how simple it is to pass a LabVIEW cluster with almost-anything-inside to a VB6 program by means of Variants.
The example also shows how to pass back-and-forth MultiDimensional arrays: of Numbers, of Strings and of Booleans,
as well as the traditional confusing-inaccurately-documented set of: 1D arrays of Numbers and single valued Numbers, Strings and Booleans.
(No need for any hardware related item)
Contributors
