Example Code
Cast Two I16 Numbers into One Double Precision Number Using LabVIEW
Code and Documents
Overview
This VI casts two 16-bit signed integer numbers (I16) into one Double Precision number.
Description
This VI uses the LabVIEW Typecast functionality by inputting the most significant bit (MSB) and least significant bit (LSB) Values and using the Join Numbers function.  It outputs the casted number as a double.
Requirements
LabVIEW 2012 (or compatible)
  1. Select the Most Significant Bit (MSB) value.
  2. Select the Least Significant Bit (LSB) value.
  3. Run the VI.
  4. Observe the Casted Number being shown as a Double Precision Floating Point Number.
Additional Information or References
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
Comments
Todd S.
NI Employee (retired)
on
great stuff!!!
Todd S.
LabVIEW Community Manager
Daikataro
Active Participant
Active Participant
on
Worked awesome, just one observation. You describe it as taking 2 Unsigned 16 bits numbers (U16) but the actual VI asks for 16 bits signed Integers (I16) and, when translated to double precision it gives an incorrect value. It worked great when translated from 2 U16 into a Single precision float. So if anyone using this notices discrepancies from source to result, try changing typecast from double to single.
