Example Code
Centroid of an ROI
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Description
Overview
The example demonstrates how to calculate a centroid of the portion of an IMAQ image.
Description
In order to find the centroid of a portion of an image a ROI (region of interest) can be used to define the desired portion of the IMAQ image. Since the 'IMAQ Centroid' function does not support ROIs the ROI has to be converted to a image mask before. Masks isolate a part of an image for processing.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Run the VI
  2. Select any available ROI (region of interest) tool and create a ROI and click OK
Additional Information or References
How Does the IMAQ Centroid VI Work?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LXISA2&l=en-US
Region Of Interest Frequently Asked Questions (FAQ)
https://www.ni.com/en/support/documentation/supplemental/21/region-of-interest-frequently-asked-ques...
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Senior Systems Engineer
Comments
WNM
Active Participant
Active Participant
on
This example only works with 8-bit image data due to a long standing and occasionally reviled weakness of the "IMAQ ROIToMask 2" function.  The example would have been more useful if it instead shows the gyrations one must go through to work with any image bit depth.
