Overview
This code snippet functions well as a subVI to specify a threshold value.
Description
This code snippet functions well as a subVI. It allows the user to specify a threshold value, and when that value is exceeded a control or indicator on the front panel will change color. For instance, if an overtemperature condition occurs in an oven (actual temp = 100 degrees, overtemperature set to 90 degrees) the temperature indicator may change from green to red. Enjoy!
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute: Use as a subVI in your code. Connect the corresponding values.
Additional Information or References:
