Overview
This script uses the Environment Variables provided by DIAdem to change the names of the files in the path.
Description
This script uses the datafilerename function to rename all of the files in a directory. You can customize this to follow your nomenclature.
Requirements
Additional Information or References
Original filenames
After running the script:
