Overview:
Shows how to add a background image to a waveform graph.
Description:
This code makes usage of property nodes to load an image into a waveform graph after being flattened.
Requirements:
LabVIEW 2012 (or compatible).
Steps to Implement or Execute Code:
1. Select the .PNG image you want to use.
2. Run the VI.
Additional Information or References:
The image needs to be within scale before being load.
You can adjust the size of the waveform graph as well.
"**This document has been updated to meet the current required format for the NI Code Exchange.**".
