Example Code
Change Windows 7 login screen background using LabVIEW
Code and Documents
Overview:
This VI allows the user to programmatically change the default background of the Windows 7 login screen.
Description:
While starting a Windows logging screen appears. You can modify programmatically the background of that screen with this VIs. This is done by adding an image to Windows registries.
Requirements:
  1. Requires a .jpg image less than 256k.
  2. Windows 7 OS
  3. LabVIEW 2012 Base Development System (or compatible)
Steps to Implement or Execute Code:
  1. Open Background Changer NI Verified - LV12.lvproj
  2. Run Main Background Changer.vi
Additional Information or References:
"**This document has been updated to meet the current required format for the NI Code Exchange.**"
Comments
LrnnLV
Member
Member
on
Hi ,
I have LV 8.6. Any suggestions as to how I can check out the VI you have uploaded. Thanks for any help.
Zbigniew_StS
Member Member
Member
on
Hi
What about Windows 7 variant?
Regards
Mikrobi (Zbigniew St. Sobków)____________________________________________________________
"You can lead a horse to water, but if you can get him to float on his back you've got something."
