Example Code
Change multiple row tab controls without the rows moving Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview:
Using an array of buttons, you can replicate the tabs, and change which one is visible in runtime using events.
Description:
Are you annoyed by the rows of tabs moving when you change tab? In this Example, you can realize changing which tab is visible in runtime by using events structure,
Requirements:
LabVIEW 2012( (or compatible)
  1. Run the vi.
  2. Use the control cluster to change the visible tab.
 Additional Information or References
Ian S
Applications Engineer CLA
National Instruments UK&Ireland
