Example Code
Changing Text Color (Based on String Tokens) Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Using the example to change the color of token your specified
Description
In this example, you can specify the word you want to change the color in a sentence, and run the code, the token will be placed with a now color.
Requirements
LabVIEW 2012( (or compatible)
  1. Specify the token you'd like to change
  2.  Run the vi
Additional Information or References
Front Panel
"**This document has been updated to meet the current required format for the NI Code Exchange.**"
Adri Kruger
LabVIEW Product Marketing
