Overview
This example demonstrates how to programmatically change and commit multiple shared variables simultaneously using Datalogging and Supervisory Control (DSC) module.
Description
This example opens up a library that houses multiple shared variables, then sets the DSC alarming functionality and buffers each shared variable. Once all of the shared variables are set and buffered, the VI then uses the Commit Shared Variables VI to simultaneously commit a large amount of shared variables. This is more efficient than setting and committing each variable during each iteration of the for loop. Finally, the lower For Loop verifies that the shared variable alarming settings were committed by reading the alarm level of each shared variable.
Requirements
Software
Hardware
Additional Information or References
Change and Commit Shared Variables using DSC LV2012 NIVerified.vi - Front Panel.png
Change and Commit Shared Variables using DSC LV2012 NIVerified.vi - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
