Overview
This Polymorphic VI accepts either a single Boolean input or an array of Boolean inputs and returns a Digital Waveform that can be wired to a Digital Waveform Graph. As a functional global variable, this VI can receive new data each loop iteration such that its output causes a Digital Waveform Graph to act as a chart.
Description
This example uses a functional global variable architecture to store samples in a buffer as they are queued using the Enqueue command. Using this buffer, some simple array manipulation is implemented to return a digital waveform with a specified window size (maximum number of samples). Sample rate may be optionally specified as well.
For an example of using this VI, please open Digital Waveform Chart Implementation.vi.
**Please note: You cannot interchange loading single elements and arrays into a polymorphic instance. You must choose one or the other (array or element) for each instance of Digital Waveform Chart Buffer (Poly).vi and stay with the same input type throughout run-time.
Requirements
Software
LabVIEW 2012 or later
Hardware
None
VI Snippet
