Description
Description-Separate-1Dependent on the OS, special characters can cause issues. E.g. Linux RT can't handle special characters or German umlauts (Startup Executable Does Not Launch on Real-Time (RT) Target).
Basically it is recommended to avoid special character in file or folder names.
It is a lot of work to check all files in a large project manually. This VI check files or folder names for special characters like Umlauts.
Description-Separate-2How to Use
How-Separate-1
- Download the VI Check Files or Folder Names for Special Characters like Umlauts (LV 2020).vi.
- Run the VI.
- Select a Folder.
- Check out the results and rename the files if necessary.
How-Separate-2Additional Information
Additional-Separate-1Software
Additional-Separate-2Related Links
Related-Separate-1Related-Separate-2
