Example Code
Check If A USB Stick Is Present On Your CompactRIO Controller
Products and Environment
    Software
  • LabVIEW Real-Time Module
  • LabVIEW
Code and Documents
Description
Overview
This example demonstrates how to check if a USB stick is connected to a Compact RIO real-time target.
Description
The cRIO controllers have a feature for data safety which enables them to switch from saving to a USB storage device, to their internal memory. If you are storing data to your USB storage device and suddenly remove it, the controller will create a folder named U (the same as the drive letter of the USB) and continue storing data there. In order to avoid this, or make sure that you only store data if the USB device is present, you can use this attached code in parallel or preferrably periodically with your code. You can use it as part of your decision making process on whether to start (or continue) logging or not.
Requirements
 Software
  • LabVIEW Full or Professional Development System 2012 (or compatible)
  • LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • Compact RIO with USB port (e.g. 9024 or compatible)
  1. Download and extract the attached file "Check USB stick on real-time target LV2012 NIVerified.zip"
  2. Open project file and follow the instructions in Front Panel and Block Diagram of "Check USB stick on real-time target LV2012 NIVerified.vi" and run the program.
Additional Information or References
Check USB stick on real-time target LV2012 NIVerified.vi - Front Panel.pngCheck USB stick on real-time target LV2012 NIVerified.vi - Front Panel.png
Check USB stick on real-time target LV2012 NIVerified.vi - Block Diagram.pngCheck USB stick on real-time target LV2012 NIVerified.vi - Block Diagram.png
Note: This example was created to be used on VxWorks real-time targets. If running this example on NI Linux Real-Time targets you might have to use different paths as described in the Working with File Paths on Real-Time Targets tutorial.
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
