Overview
This VI opens an HSDIO session using NI-HSDIO to check the onboard memory size for your 654x, 655x, or 656x device.
Requirements
Software
LabVIEW 2012 (or compatible)
NI-HSDIO driver which is compatible with your hardware and version of LabVIEW
Hardware
Instructions
1.Select the resource name of your devices. An array of devices may be selected if necessary.
2.Run the VI.
3.Results are displayed on the front panel which tell you the Serial Number, Total Acquisition Memory Size, Total Generation Memory Size, and the Mbits/ch of your device.
Additional Information or References
p.png)
d.png)
